I would like to put this to rest once and for all. 1) What casting should a 67 master cylinder be with the J50 vacuum power brakes option? 2) What stamping should it also have? Is it DC, PG or something else? 3) Are the master cylinders stamped/cast with a date code? 4) Lastly is the internal bore the same or is it larger with a power brake set-up.
Thanks in advance.
Jimmy Blakely
Thanks in advance.
Jimmy Blakely
