C1/60 Door stricker problem - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    We had to drill the bolts to remove the strikers. If we need to replace the backing plates, what's the best way to get at them?
    Larry
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1/60 Door stricker problem
    Pull the gas tank cover,or I would step up drilling till it was close to the bolt size , then re-tapp them.
    • Larry P.
      • June 30, 1999
      • 481
      The gas tank cover is off. I still don't see a way to get at the banking plates.
      Larry
      • Dennis A.
        • April 30, 1999
        • 1010
        Larry...
        On the drivers side, you must remove the gas filler neck. If the stamped cage that holds the threaded plate has broken loose form the rivets, best to pull the plate, rechase the treads and hold in place as you mount the door strikers. If the cages are in good shape, you can retape (rechase the threads from the outside and remounting will be no problem.
        • Roy B.
          • February 1, 1975
          • 7044
          Larry ,sorry I for got to tell you , you need to remove the tank filler tube.
