My Top Flite 1967 Roadster has an unusual problem, so I'm looking for ideas. It has stainless resleeved calipers all around and same in its master cylinder. (Non power brake system). It is loaded with silicon fluid, and everything was new a few years ago. After driving 3-5 miles, even with absolutely no use of the brakes, the brake pedal gets very hard, has no play at all, and then the brakes proceed to "drag", to the point where I need to downshift to keep up enough power to overcome the brake drag. Heat at all 4 corners seems about equal. Usually after allowing the car to overcome the badly dragging brakes by driving with extra power for several miles, it suddenly seems to return to normal. It will actually function perfectly for the next driven miles. The pedal play will return to normal, the dragging vanishes, and the brakes work flawlessly for up to several hundred miles just fine. But when the car is cooled down overnight, and the problem repeats itself.
Any ideas where I should start to look for solutions?? Strange problem. This happened daily on the NCRS Road Tour to Hershey last July, and only stupid pride and a "lead foot" allowed us to "drive through the problem". After 4-5 miles it "shook off the problem" and returned to normal for the rest of the day.
