I request some advice from this wonderful forum on clutch adjustment on a 67 SB. I have read the archives and service manuals and still have a few questions.
There are two configurations of the clutch - quick and slow actuation. Which config is standard?? Which do most people use? With mine in the slow (less force required) configuration, the adjusting nut on the rod is at the extreme end of the rod, and even with it this way the disengagement/engagement point is very low to the floor. If I were to adjust the linkage as the manual says, it would probably barely disengage at all. I can't believe that GM wanted the clutch adjusted such that the release point was almost at max travel.
I am looking for comments regarding the two configurations of the clutch, which was the factory standard that corresponds with the AIM, where the engage/disengage position turned out to be in the pedal travel, general thoughts on the relative leg force with each, etc.
