D&M Restoration opinions - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hello,
    Has anyone used D&M Restorations for gauge cluster restorations? Any opinions on their work good or bad?
    Thanks.
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: D&M Restoration opinions
    I have used them on 2 occasions. The workmanship was excellent and the turn around time was great. I also had the opportunity to see their shop. They do a tremendous business in "Anything dash" restorations for all types of cars... not only Corvettes. They have been doing restorations for many years. I highly recommend them.
    • Rex Kelly
      I had a '65 with a bad speedo and tach. I sent it to D and M and the work was excellant and only about a week turn around. Later, I sent a '57 radio, again the work was superb but understandably, the turn aroung was a bit longer....I will use them again without hesitation...
      • Don22567
        I have used D & M restoration several times and have found there work to be of the best quality. The only thing that I found that I didn't like was the "red" color that they put on the tachometer and water temperature guage. It is closer to "pink" than it is to the "orange" color that came originally on these guages. I found this to be the same though with other guage restoration shops also.
