I see many people on E-Bay buying or selling the wrong lighter .
1. A 55 to 57 car lighter won't fit in a original Corvette socket.( they are to large in diameter)
PS. if a Chevy is used in a Corvette , then the female housing has been changed.
2. A car lighter has a brown Bakelite area of the lighter
3. A 53 6V and 55 12V "only"as you see has a porcelain white area of the lighter showing and slits that can be opened more to hold the lighter in.
4. A 53 & 54 6V wire raping ( the hot end ) is much less
5. The 55 12V wire raping again ( hot end ) is more or larger in area the the 6V. ( that is how you can tell the difference between the two if you cant read the voltage.
6. The 56 and up the white porcelain area is shielded with a cover, see pic.
Yes the 55 and 56 up will interchange or fit.
And yes all comments are welcomed good or bad~
