Hi all,
Just as a lessons learned which I do want you all to learn from:
I was just installing my new main wiring harness, everything went fine until I connect the fuel gauge. The complete brown wire melted away, over the whole length from the gauge to the fuel tank before I was able to cut the power.
Well, appearantly the metal fuel pipe exiting from the fuel level sensor cover was touching the bolt where the brown wire connects to the fuel sensor. This shorted the circuit to ground. I can't understand this design making this possible at all! I hope my fuel gauge still works and haven't melted as well.
This all means another $78 for the rear harness (which was still in great condition before the disaster) and an ugly (non correct) brown wire to run from the rear harness connector to the fuel gauge and some non-serious damages to my main wire harness (some of the surrounding black tape melted). I'm in missery...
greetings,
Rob Musquetier.
The C1 1959 Corvette Restoration Project
greetings,
Rob Musquetier.
