correct valve covers 69 L 46
  • Tom Stanton (41491)
    • March 1, 2004
    • 1087
    #1
    I have cast aluminum valve covers on it now. Acording to 1 book I hvae the bolts should have an M on them, they do not.But I couldn't find any thing telling me what valve covers it should have on it. Thanks in advance.
    Tom Stanton
  • Joe Lucia (12484)
    • 42936
    Re: correct valve covers 69 L 46
    Tom-----
    The 1969 L-46 used cast aluminum valve covers that were first used for 1969 Corvettes with L-46 and 1969 Camaro Z-28s. These were the aluminum covers with provisions for the PCV system. One side had an emblem with the crossed-flags logo and the other side cover had provisions for a twist-on oil filler cap. The 1969 valve covers also had NO drippers on the inside, upper surface as did 70+ valve covers of the same style. The 1969 covers were more-or-less an "as-cast" finish and were not polished.
    • Terry McManmon (3966)
      • October 1, 1980
      • 15488
      Tom,
      While most 1969 to 1972 Corvette SB with aluminum valve covers had fasteners with the M headmark, not all did. Unless your bolts are chrome plated, or otherwise have some indication that they have been replaced, don't worry about the headmark.
        • March 1, 2004
        • 1087
        Joe and TERRY
        Thanks for the info I geuss mine are correct.They are unpolished and have the flags and ports the the pvc valves.
        Thanks Tom
        • george romano
          If you want to buy the bolts with the M headmark, Paragon carries them. I just bought a set from them at the Florida Winter Meet.
          George
