'67 COUPE VENT WINDOW HANDLES - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    It appears that the vent window regulators are original to my car. I repaired them to eliminate the in and out play and they operate fine now. The handles however, are almost 3/8" from being flush with the door panel with the window closed. Can I assume that someone has replaced them with incorrect repros or replacements and that they originally did fit flush with the panel? I know there's a lot of info regarding this and the grooves in the handles and so forth in the archives, and I'll be checking there also.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: '67 COUPE VENT WINDOW HANDLES
    the vent window regulator shafts of roadsters are different lengths than the shafts of a coupe regulator. mike
    • Blake W.
      • April 30, 2001
      • 164
      Rod, For what it's worth I have a 67 unrestored coupe. My vent window handles don't fit flush either. Blake
      • Rob A.
        • December 1, 1991
        • 2126
        Thanks, that saves me trying to fix something that doesn't need fixing for a change.
        • John R.
          • September 30, 1999
          • 288
          Rob,
          Mine are the same in my 67 coupe and I believe that the regulators are original. I attributed this anomaly to aging of the door panels which are also original to my coupe.
          • Rob A.
            • December 1, 1991
            • 2126
            Thanks John...
            • Gene M.
              • April 1, 1985
              • 4232
              Rob,
              The roadster vent window mechanism has a longer shaft on it than the coupe does. Also repop door panels fit closer to the door than the originals do giving the handle a gap to the round bezel. The 3/8 inch sounds like wrong roadster window mechanism. The panel can be spaced out locally to fit correctly with the coupe window mechanism. Attitude of the shaft can be a problem to compensate for to seat the handle square against the round bezel.
              • Rob A.
                • December 1, 1991
                • 2126
                Sounds like a combination of things can be causing the gap, including poor factory fit. I did notice that the one that sticks out the most has a wider groove for the snap ring than the other, causing part of the problem. Maybe I'll try another handle...Thanks...
