C1 62 lower air cleaner refinish - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    What type of finish should be on the lower part of the air cleaner (flat plate)? Any idea on how to clean/refinish? Mine seems to be black stained and carb cleaner will not remove. Also the area where the filter sits seems to be worn through.
    thanks, Chris
  • Jerry C.
    • November 1, 1995
    • 741
    Re: C1 62 lower air cleaner refinish
    Think I would buy a new one. Once cleaned you have the silk screening to deal with. CC sells the base for about $50.00.
