Spot weld on hinge covers for C1? - NCRS Discussion Boards
  • Kevin Riel
    I am replacing the hinge covers on my 59. I took the two cover screws off, but the covers won't come off. It seems there is something holding them in the center. Are they spot welded?
    Kevin Riel
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Yep, believe so... DC *NM*
    • Roy B.
      • February 1, 1975
      • 7044
      Re: Spot weld on hinge covers for C1?
      They are part of the hinge as you remove the whole thing
      • Kevin Riel
        Ok, but what about the replacements? Do they just "cap" on top of the hinge? Do you have to remove the whole hinge if you are just going to replace the hinge cover?
        Kevin Riel
        • Mike M.
          • May 31, 1974
          • 8365
          if you intend to have the car judged, pull complete hinge, drill spot welds to remove original caps, then spot mwled repos onto hinge main body. mike
          • Roy B.
            • February 1, 1975
            • 7044
            Kevin! yes I think they just do that.
            • Kevin Riel
              Thanks to all! *NM*
