According to vendors at the Houston Corvette show this past weekend (you experts can confirm), a uniqueness about the 67 year master cylinders was that only that year the same part number MC was used for both regular manual brakes and for J50 power brakes. J56 heavy duty power brakes used a different part number. In reviewing my AIM, this appears to be the case (but I didn't know it was only 67 like that). Other later years (according to the brake vendors at the show) used a 1 1/8" bore MC for power brakes and a 1" bore for manual brakes. When you go out to buy either a new or rebuilt MC for a 1967, chances are you will be asked if you have manual or power brakes, and get a different part based on the answer. So, that means there are probably many owners of 67's out there with 1 1/8" bore MC's even though all factory units were 1" and vice-versa, and I am one of them!
So, the question to the experts, what is the end effect of having the larger bore unit compared to the smaller bore with power brakes? The engineer in me would lead me to think that with a smaller bore MC, it would be easier (with more stroke) to apply the brakes on a manual brake car. This might lead to grabby brakes when the same MC is mounted on a booster? I'm thinking that using the 1 1/8" bore on a 67 might actually be a good thing since GM switched to that in 68? Comments?
