68 door window channel grease - NCRS Discussion Boards
  • William C. Brown
    Gents,
    I'm restoring the window crank mechanism in my 68. What type of grease should I use in the window channels? I want something that will provide a nice smooth action in the summer as well as the winter.
    --Corey #33787
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: 68 door window channel grease
    Corey, I suspect the factory probably used "Lubriplate" white grease, but by the time I took my doors aprart, the grease in the window mechanism was black with dirt and wear particles.
    Unless you live in Alaska, winding resistance shouldn't be appreciably greater regardless of the grease type. I am not a big fan of "Lubriplate", because I have seen too much of it dry out into chunks. It's when the grease dries up that you definitely feel increased winding resistance. I will probably use a good quality molybdenum (?) disulfide chassis grease when I put my doors back together.
    • William C. Brown
      Thanks for the response Chuck. I actually found some stuff that I like
      at Lowes today. It's got molybdenum in it and it's nice and light. I also
      looked at some sprays that have teflon, but I think the grease will work
      better. What a job getting the entire mechanism out! Can't wait to try
      and get it all back in. :-)
      Thanks again
      --Corey
