I hooked up the headlights to try them and check that they are working correct. When I turn them on the high beam red light is on and no high beams. When I hit the dimmer switch the high beams come on but weak like a short and the red light stays on but also dims can't be a short or a fuse would blow. I've tried jumping the ground wire at the rad support. Nothing it stays the same. Any ideas where else to look. Its a complete new harness from Lectric.
Thanks Mike
Thanks Mike
