C1 Latch hardware - NCRS Discussion Boards
C1 Latch hardware
  • Kevin Riel
    C1 Latch hardware
    I'm just about done with the door jambs and such on my '59. I've got a lot of help from you people along the way!
    I'm assuming that the screws for the latch should be exterior color, and that the screws for the striker should be cadium plated. Is this correct? Also, should the screws that hold the rear window channel be black oxide or exterior color?
    Kevin Riel
  • John M.
    • January 1, 1999
    • 1553
    Re: C1 Latch hardware
    Kevin,
    The screws that hold the rear window run should be cad/Zinc plated. All the rest you are correct on. The latch on the door should be masked so that the part that protrudes from the door should be plated while the rest should be painted.
    Regards, John McGraw
