ok, I hate to be yet another member with a "my C2 runs hot", but I am looking for some new avenues to pursue -
before I tell you my tale of woe, here is what has been done thus far (car in question is a 1965 L76):
- Correct Dewitts-Harrison repro Rad
- Correct/rew hoses
- correct water pump (Goat Hill supplied)
- correct fan, new 3916141 clutch (note to Joe L - yes GMPD still stocks it)
- yes my gauge reads 10 -15 hot, I know because I have shot the man with an IR gun, and that should answer the "how do you really know it is running hot" question.
- Timing/Dwell set to specs, all seems to be well there
I have gotten firm control of my earlier run-hot situation around town thanks to the correct rad (replaced a brass job). And yet, the thing runs hot hot hot at highway speeds, even on a day like today on the low 40s . . . yes I suspected the lower rad hose was collapsing, and yes I replaced it once to be safe, no fix . . . once I coast the temp comes down in seconds. Is it possible that I have a blockage somewhere, or my water pump is not functioning well? I am out of tricks, I have researched this topic here and on other C2 forums, I think I have followed the drill - the collective wisdom here is sought.
- Correct/rew hoses
