This was the answer to a members question== What do you say or know???
In 1955 and early 56 the lower "FOUR" piece shroud which vary few people know about didn't have the two holes your talking about. BUT two little holes forward of the bottom piece using two clutch head screws that supported the "FOURTH" metal piece that was also screwed to the lower Radiator shroud . All to gather there was "FIVE" metal pieces for the radiator shroud.in 55 and 56. But later 56 till 59 the same shroud was used but it now consisted of "FOUR" pieces with the lower piece still showing the two little forward holes( not used any more) and now also the two large holes your talking about., bolted to the cross member.
I think G.M used up the early type shrouds till they ran out , so you may not see it bolted to the member or your's, or was replaced with the early repro's.
It is vary rare to see the front lower #5 shroud piece on a restored 55-56 Corvette because it's not repro'ed and not judged, and only a few people know about it.
Seems no one ever ask about the "TWO" little hole tho!!
I would take a pic. of it on my 55 , but is so daing hard to see>
