Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 Warning: Undefined array key 0 in .../vb/user.php on line 530 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 530 C3, Crankshaft Balancer - NCRS Discussion Boards
  • David J.
    Infrequent User
    • May 31, 2000
    • 28
    I have a 1969 with the 350 CI with 350 HP. The balancer is showing its age and the rubber ring is rubbing ont the timing cover. Is there a company that rebuilds old balancers and have you heard what the cost of a rebuild is? Thank You, David
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: Check the archives Dave
    There are threads which speak of outfits who restore & repair balacers.
    Hope this helps if you get no other hits.
    Chuck
