I took the rear suspension (spring, both control arms, 1/2 shafts, and shocks)
out of my '67 to detail the bottom. I just got done with putting all the parts back onto the car. Now the car is about one inch higher on the drivers side then the pass side. I removed the spring again and flipped it around, thinking that one side of the spring may be weaker then the other, NO luck, same thing. The spring is in the center hole, and I don't torque the bolts until the car is sitting on the level surface. Is there anything I should check? or adjust? Thanks Ken
