C1 Trailer hitch Right On - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    I've had people E-Mail me about towing my Tear Drop Trailer asking how I put the hitch on. See other post and pic. too! Simple I designed the hitch as you see (three sided ) with two bolts holding it. The receiver bar was bent to clear the back, I also added AIR shocks , you can see where the tire cap is located .The wiring comes out at the bottom body drain hole.
    My 1947 trailer weight 500lb. when adding my wife wardrobe add another 200lb, this and that stuff another 100lb , my stuff 50lb. My 55 is all stock 195hp V8 and the Corvette doesn't even know it's back there.
    Yes stopping I give my self a little more time. But traveling all around the USA and Canada we never had any problems, but for people asking , do you sleep in it. And yes, we do now and then we cook in the back kitchen.
    Pulling trailers behind classic and hot rods here in Ca. is becoming a big things on road trips.
    People never know it's there and it was the best thing I ever added. OK I'll take a point drop.
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 Trailer hitch Right On #2
    OK ! Don't dump on me to bad, we use our Corvette.
    • Roy B.
      • February 1, 1975
      • 7044
      Re: C1 Trailer hitch Right On #3
      We had our other hard top on in this pic. Original 50's mud flaps.An other 55 G.M Dealer option S/S hub caps used on the trailer, also vary rare.
      • Kevin M.
        • November 1, 2000
        • 1271
        (Message Deleted by Poster)
        • Kevin M.
          • November 1, 2000
          • 1271
          Roy,
          I met you and your trailer at Monterey, although I didn't know as much about you as I have learned lately. Wish I'd spent more time BSing now.
          Kevin
          • Roy B.
            • February 1, 1975
            • 7044
            Re: C1 Trailer hitch Right On "Kevin"
            OK I'm full of BS, next time Thanks
            • Tom P.
              • April 1, 1980
              • 1814
              I have fabricated a hitch for my 56 which is mounted to the rear cross member similar to the way Roy's is mounted. Although, when not in use, I remove the complete hitch from the car. I have a trailer that is smaller than Roy's trailer, but still kind of tear drop shaped, with a lid that is hinged at the front of the trailer and it also has a tail gate. The trailer sure makes a difference for long trips because I can carry so much more "stuff". I also have a jet boat which I sometimes tow to the lake behind the 56.
