63 radiator support
  • Rainer S.
    • June 1, 2003
    • 468
    #1
    63 radiator support
    I have searched for a long time for a 63 Fuelie radiator core support. Cant find one (My car ended up with a 64 unit for some reason).
    Decided to replace it with a reproduction unit.
    I have seen them listed in catalogs from DR Rebuilt and CC. Who sells the best Repro ?
    Rainer
    • 42936
    Re: 63 radiator support
    Rainer-----
    I believe that all of the reproduction radiator supports on the market are manufactured by Coffman Manufacturing.
    • Sydney G.
      • February 1, 1994
      • 441
      Rainer,
      It is my understanding that G.M. at some point decided to use the FI core support for all applications as a replacement part. I have searched for a non FI '63 only support for some time as my car seems to have this over the counter replacement support with the oval FI opening. I missed out on a couple this past year or so.
      I have however seen quite a few '63 FI supports for sale claiming to be the original deal. Maybe you should hold out just a little bit longer as this seems to be more available than the non FI '63 only core support.
      They seem to be out there!
      Syd
      • Steve G.
        • June 1, 1994
        • 229
        Want mine??
        My split window had a body off in the late 70's, and over the counter GM parts were used... it has a radiator with the correct part number, but with a '76 date code... and it has a FI replacement support. (the car is a 327/300) I'm headed to VetteFest next weekend and I plan to buy/order a dated radiator, non-FI support and replacement shroud.
        Need a FI support?
        • Rainer S.
          • June 1, 2003
          • 468
          Re: Want mine??
          I have seen F.I. radiator supports for sale on Ebay, but they were all the later version, with the straight, lower front brace. Those were used on late 63's , 64 and 65 Fuelies. The one I need has the curved brace.
          Rainer
          • Dave F.
            • December 1, 2003
            • 100
            Coffman Corvette - I just got core support brackets for my '68 from them, and they are dead nut "ON" for correct replacement. Nice folks too.
            • Joe S.
              • August 1, 1999
              • 319
              Could someone tell me if this is the "hump" where the horns mount that is unique to 63? IT also has a slightly oval hole for the S-Tube.
              Joe's 63 FI Convertible
