Question about 1963 Cooling Fan Blade Rivets - NCRS Discussion Boards
  • Jack U.
    • November 1, 2003
    • 212
    The judging manual indicates the rivets on the fan blades are "round button heads". I'm trying to get a good picture of what to look for. Are these heads "flat" top or "rasied" top as in a dome-like shape?
    Jack
    Re: Question about 1963 Cooling Fan Blade Rivets
    Sometimes called mushroom head...the early fans used rounded top or 'dome-like' rivets. Later versions of the same fan (around 1965) changed to flat or pancake head rivets sometimes called button head. Your interpretation is correct (dome-like).
    • Jack U.
      • November 1, 2003
      • 212
      Is attached picture correct or incorrect?
      Would you say the attached picture is correct or incorrect?
        Re: Is attached picture correct or incorrect?
        Jack------
        The picture is correct. However, I would say that the rivets are incorrect.
        • Mike M.
          • May 31, 1974
          • 8365
          agree with joe, flat top rivets atypical. like to see dome-shaped rivet heads. mike
          • Jack U.
            • November 1, 2003
            • 212
            THANKS ALL! *NM*
