If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I have a 69 L-46 350/350 4-speed. The Rochester carburetor has the following number on it 7029207 DA (which is correct) and a Date Code of 0251, which means Jan 25, 1971. (correct?) The car's time built code is F21 which correlates to Jan 21, 1969 (a time that it passed a point on the assembly line.)
Is this carburetor a service replacement that was made on Jan 25, 71 or am I miss reading the Julian date?
You are interpretting the date code correctly. However, this particular carburetor was manufactured for many years for use as a SERVICE carburetor for all 68-69 Corvettes and other 68-69 Chevrolets with 4 barrel carb. So, it's possible that the "1" could refer to 1981 or, even, 1991. It's really a point of little significance, though-----no GM #7029207 carburetors originally used in PRODUCTION for 1969 could have had a "1" in the year position of the date code regardless of what year that the "1" represented.
Chuck, you have the Julian date correct for a Rochester carb.
Without knowing when the carb was installed, it is difficult to know if the carb is a service replacement or a rebuilt original carb. It is possibile that the carb was an original carb from a 71 that had been rebuilt and sold through an auto parts chain many years later.
Two or three years seems like a short service life for a carb, and unless a service carb had been setting on the dealer's shelf for a long time, a new service carb would seem likely to have a later date than 71.
FWIW, my 70 350/300 had a rebuilt carb originally from a 69 350/350 when I bought it. Most likely, the carb had been rebuilt to 70 350/300 specs and sold as such, but the body was still stamped for the 69 350/350.
A GM #7029207 carb with a 1971 (or, 1981 or 1991) year of manufacture has to be a SERVICE carb. Carbs of GM #7029207 were not used in PRODUCTION for 1971 or later---they are a 1969-only carb part number. So, any carbs of this part number with a date after 1969 have to be a SERVICE carb. Like I mentioned, though, the "1" does not necessarily represent 1971.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
