If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Some time ago I purchased GM Special Formula Multi-Purpose Rear-Axle Gear Lubricant part no. 1052271. This is no longer available and has been superceded by part number 89021671. Was there anything "Special" about the original lube or was it just marketing hype for standard 90W gear lube? The replacement lube says it is 80-90W gear lube nothing "Special". Can I use a good brand of gear lube without any problems? I know I have to put in the limited slip differential additive.
george: go with a brand name 90 wt gear oil and add the posi addative(i like kwell , a spermaceti(whale oil derivative) product, 4 oz. ) Most GM "SPECIAL" lubricant/fluids/antifreezes etc, are "hype" at best.mike
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
