I had dropped off the boss's '62-340 at Corvette Mike's on Monday for them to look at the tranny and shift linkage, as she was slipping out of third gear, getting stuck in two gears at once, and the shifter was buzzing like a beehive at speed. (That enough symptoms for ya?) In any case, I got a call today, they've got her apart and said that third gear is bad and needs to be replaced, fair enough. They also said that the main tranny case and tailshaft housing BOTH needed to be replaced. The tailshaft housing has a fracture thru one of the shifter mounting bosses that would be 'expensive' to fix properly, while the main tranny case is apparently no good because, if I understood correctly,one of the recesses in the case itself is so worn that the number of shims required to hold whatever (layshaft? total guess on my part) goes in it would be a temporary and ill-advised fix. I have the entire powertrain photgraphed and have all the P/N's so I'll be sure that I get all the original (correct!) pieces back.
So- She's coming back with a new shift lever assembly, tranny case, and extension housing. From this admittedly confused report, can anyone tell me what was wrong with this tranny? The car did have racing stripes on it at one point, FWIW. I don't know what replacement case they're using, but given that it's going to be mounted to an RPO 396 motor, are they limited to some particular species of T-10, or will any cast-iron Chevy passenger T-10 work? They quoted $85 for a replacement case, so I'm guessing it's the latter. Any opinions here? (Other than I'm a dummy for not being there when it came apart and seeing the damage firsthand, and that it's clear I don't know much about transmission rebuilding!) Thanks!
