I was challenged to replace the pinion seal sooooo, per my handy shop manual marked the relative positions of the yoke, shaft and nut for ease of re-assembly.
In an earlier post I was concerned about how to start the nut as my trusty ole Craftsman breaker bar wasn't cutting the mustard. Well I finally placed a 3' pipe over the end of the breaker bar and finally the nut released.
Now that it's time to re-torque the nut, I attempted to pull the nut in with just the breaker bar but cannot get the nut back into proper alignment with the other marks.
NOW, my question is this, was the nut just corroded in place requiring the pipe on breaker bar setup to break it apart, or will I also need to use the pipe over bar method to once again hit the marks?
I fear over torqing the pinion crush collar or worse putting excessive strain on the gear assembly.
I was told about checking the torque required to spin the yoke as a re-assembly guide, but of course I found this out after it was apart!
Appreciate any "Been There" "Done That" wisdom
Feel like ole Bubba on this one ,
Chuck
Chuck
