LT-1 with AC fan shroud - NCRS Discussion Boards
  • Tony 38901
    What would be the correct fan shroud for a '72 LT-1 w/ AC? Would part # 3956109 be correct? Are the part numbers found anywhere on the shroud? Does the AC option even make a difference in this case?
    Tony
    Re: LT-1 with AC fan shroud
    Tony------
    GM #3956109 is the correct fan shroud for the application described. In fact, GM #3956109 was used for ALL 1969-72 Corvette small blocks also equipped with copper/brass radiators. That includes 1972 LT-1 (except ZR-1) with or without A/C. 1972 LT-1s, with or without A/C, also received fan shroud extension GM #3956118.
      Addendum
      Also, the part number is usually found debossed on the upper right corner of the shroud.
