67 Big Block hood - NCRS Discussion Boards
67 Big Block hood
  • Rex T.
    • December 1, 1984
    • 455
    67 Big Block hood
    How can I determine beyond a reasonable doubt that the 67 BB hood that I just purchased is an original and not a repro or an "over-the-counter" GM replacement? Thanks in advance for your help. Rex #8089
  • Tom D.
    • September 30, 1981
    • 2126
    Re: 67 Big Block hood
    Was it the blue one that was on e-bay? Had the weatherstrip on it...
    Send me a digital photo, and I will compare for you.
    Tom
    4889
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Rob A.
      • December 1, 1991
      • 2126
      In addition to the obvious original design vs. some reprodution or after-market, check for a thin seam line that runs around the entire edge of the back side of the hood. This will also tell you if the hood has been "trimmed" to fit a car with a non-original hood surround. You can also check the rivets which should be smooth, with no concentric rings in them.
