C2 Half Shaft - NCRS Discussion Boards
C2 Half Shaft
  • Scott S.
    • February 1, 2002
    • 62
    C2 Half Shaft
    My 65 Roadster has the larger 3" half shafts. By using the larger size instead of the 2 1/2", does it or will it affect rear alignment? Does the larger size affect the suspension height?
    Re: C2 Half Shaft
    Scott-----
    The use of the 3" OD shafts will cause absolutely no problem, whatsoever, when used on a 1965, or any 63-79, for that matter. Although the 3" shafts were used in PRODUCTION only for 75+ models, they have been the GM-approved SERVICE replacement shafts for all 63-74 Corvettes for the last 25 years, or so. They're not CORRECT, of course, for 63-74, but they are 100% functional and compatible with everything else on your car. There is no need to modify any alignment settings or any other adjustments when using the 3" shafts to replace the 2-1/2".
