Exhuast System - NCRS Discussion Boards
Exhuast System
  • Michael M.
    • April 1, 2002
    • 149
    Exhuast System
    I've been studing my AIM, and my judging manual and have a question. How different are the manual transmission vs. the automatic transmission exhaust systems for a '72 LS5???
  • Michael M.
    • April 1, 2002
    • 149
    Should Read *** Re: Exhaust System *** *NM*
    • Chas Henderson #28127
      Re: Exhuast System
      Only the center bracket where the pipes are clamped to the frame is differant. And I guess the transmission cross member is bolted in on a auto and welded on with a 4-speed.
      Chasman
        Re: Exhuast System
        Mike-----
        They are absolutely identical EXCEPT for the right side exhaust pipes, front and rear. These are configured a little bit differently in order to clear the larger transmission profile which the THM-400 has in contrast to the much more compact Muncie 4 speed.
        • Harmon C.
          • August 31, 1994
          • 3228
          Re: Exhuast System
          Mike The 4 speed RH exhuast comes centered in the hole in the croosmember. The auto. has a bend and is crooked in the hole. Lyle
          Lyle
