I was just wondering if someone could inform me of the location of this event this summer so I can plan ahead for car and hotel bookings. Thanks
NCRS National Convention in Windsor
Re: NCRS National Convention in Windsor
Links can be found on our site also - Click on www.MichiganNCRS.org - Then select "Events" from the list on the left side.
Let me know if this does not work for you.
The source of the information is the Ontario chapter.https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
Re: Global Convention in Windsor
Thanks guys. I already had the events site in my favorites but I couldn't find an actual address of where it is to take place. If anyone has this address I'd really appreciate it. Thanks again.- Top
Maybe this:
or
plus a little leg work with your favourite search engine would be enough?
All the details are in the Driveline also.- Top
Greg -
The above links will take you to the National Convention website, which contains all the information you need (along with the 12-page center section in the "Driveline"). Host hotels are the Windsor Radisson and Hilton, and the judging field is outdoors, in a city park, right on the river. Note that you won't be able to book an NCRS-rate reserved-block room at either hotel (which are physically adjacent and share facilities with the Cleary Convention Centre) until you've registered for the convention and have received your registration confirmation and a hotel confirmation card from NCRS-Cincinnati, which is standard practice for National Conventions. See you there!
John Hinckley
Convention Co-Chairman- Top
