1967 Coupe Vent Window Regulator Sloppiness - NCRS Discussion Boards
  • Paul L.
    • November 1, 2002
    • 1414
    What causes the sloppiness in that regulator and what is the fix?
  • Ed Jennings
    Re: 1967 Coupe Vent Window Regulator Sloppiness
    Worn pot metal gears are the culprit. A new gear is now available from a company called America's Finest something. They advertise in Driveline. Very easy to install and cost about $65 or thereabouts.
    • Bill Stephenson
      Ed,
      ------Looseness can also be from the end plate walking away from the housing. as a matter of fact its more likely! Those end plates are only peened on and when someone cranks too hard on the vent cranks for long enough,the end plates work thier way loose. Taking the doorpanel off can answer the question,and the repair is something anyone can accomplish in a couple of different ways pretty quickly!...............Bill S
      • Paul L.
        • November 1, 2002
        • 1414
        Ed,
        Thanks. This is what I found.
        • Ed Jennings
          Paul, that's probably what you need. Some folks have found that tightening the rear cover of the regulator will tighten it up, but after 35-40 years of use, most of the gears are worn. On my car, the last two gears were worn completely off on the left side. These are the two that have pressure on them to close the window tight.
          • frank mccracken
            I just installed 2 of those kits. Had to do some grinding on the lower vent window shaft to get the best seal but I took my time and am really happy with the kits.
            • Paul L.
              • November 1, 2002
              • 1414
              Thanks everyone. I will yank them out and do a diagnosis before ordering parts. Those darn gears are not cheap!
              • Rob A.
                • December 1, 1991
                • 2126
                When you remove the regulator, if the back plate, (which is only marginally attached by peening over part of the main body), is loose, you can re-attach it by grinding flush the body attachment points, drilling holes, tapping and installing small bolts where the body was attached to the back plate. The restorer magazine, volume twenty-four, number two, fall 1997 has a good article on doing this. I did it to mine, and all the play was removed and they operate like new.
                • Ed Jennings
                  Not cheap, but a whole lot cheaper than NOS regulators or good used ones were before thay came along. Those have only been available for 1-2 years, and prior to that the options were very limited.
                  • Paul L.
                    • November 1, 2002
                    • 1414
                    Rob,
                    Thanks for that tip. I will pull those units soon and see what the needs are.
