Hello, can anyone with a 72 vette tell me what voltages they read on the resistance wire (hooks to the + side of the coil) with the ignition in the OFF, ON and START positions. The problem I have is that I burned up my distributor the other day. Since then I have been going over wiring diagrams and reading manuals like crazy. It is MY understanding that in the OFF position voltage should be 0 volts, ON position 7-8 volts, START position 12 volts. What I have found on my car is the OFF position 5.5 volts, ON position 12 volts, START position 12 volts. This is with the wire disconnected from the coil and the yellow wire disconnected from the starter solenoid. The engine wiring harness is new. There seems to be 5.5 volts coming from somewhere else. Is this normal?
Please help!
Scott
Please help!
Scott
