C1 spark plug shields, locks and spacers - NCRS Discussion Boards
  • terry leeker
    My question concerns the Exh. Man. assemble sequence on a 1958 radio delete car. Is it manifold, shield, spacer washer, french lock and bolt? Also, the center long bolts, two are marker as the shorter bolts are with a circle and "M", and two with "KS". One is 1/8" longer than the other (I forget now which one). Is there a purpose for this?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C1 spark plug shields, locks and spacers
    Terry - Manifold, spacer washer, french lock, bolt on 1,7,2,8... The M bolts sound pretty good to me. Spark plug shield should not be part of the equation as it bolts to the block. Best, Dennis
