LT1 RPM Question - NCRS Discussion Boards
LT1 RPM Question
  • Todd Stevenson
    LT1 RPM Question
    Greetings All,
    I have a question. If a 1971 LT1 with M22 trans and 3.70 gears is traveling down the highway at 60 MPH, how many RPM's should the engine be turning at that point, generally speaking. Please let me know your experiences.
    Todd
    #40534
  • Warren F.
    • December 1, 1987
    • 1516
    Re: LT1 RPM Question
    Todd:
    Sounds like you've got a rare ZR1 edition of the LT-1 option! I have a '71 LS6 with M22 & 3:70 gears, I also have original F70x15 Goodyear Wide Tread tires as well. Tach says 3100 rpm's @ 60 mph.
    • William C.
      • May 31, 1975
      • 6037
      a 3.70 is very close to 20 mph per 1000 rpm in 4th gear.
      Bill Clupper #618
        • 15610
        3.7 x 775 = 2867.5 *NM*
        • bruce11495
          From someone who has an LT1, its' generally half the speedo. 60MPH-3000rpm, 70mph-3500rpm etc.
            • 15573
            Bruce,
            The ratio of rpm to speed that you mention is typical of 4:11 gears.
            • Gary S.
              • July 31, 1992
              • 1628
              You can also estimate your numbers using the following web sites:
              http://www.idavette.net/tech/ratioc.htm &
              If you know your tire diameter, then fill in the gaps.
              Gary
                • 15610
                I don't know why you guys want to make this so complicated. Just multiply
                the OE tire revs per mile times the axle ratio to determine revs at 60 as
                I did in my "NM" response higher up the thread. The OE tire revs per mile
                are:
                53-64: 760
                65-72: 775
                73-82: 760 (775 for 255/60R-15)
                Speedometer gearing for all tires is the same; 775 rev/mi tires just adds about 2 percent error on the high side.
                If you know that your speedometer and tachometer are reasonably accurate you can rearrange the formula and compute axle ratio from speedometer and tachometer readings.
                • bruce11495
                  I've had the car for 20 something years and thats what I remember it as, give or take a couple 100rpm. I know the speedo is dead on after running it on the dyno.........
                  • Barry Chappell
                    I've owned my '70 LT-1 since new. M21, 3.70. Speedo has always read 2,700 at 60 MPH. Duke's formula is correct. My tach could be off by 100.
                    Unless GM screwed up my speedo and/or speedo gear, then 2,700-2,800 is correct.
                    Barry
                    • Todd Stevenson
                      LT1 RPM Question
                      All,
                      I thank you for your responses. Based on what I have read I guess mine is OK, it reads 2900 RMP at 60 MPH. It is very interesting, however, how many different techniques there are in figuring this out. Thanks for the education.
                      Todd
                      • Todd Stevenson
                        LT1 RPM Question
                        Thanks for the response. The RPM's seemed to be high, but based on the
                        responses I've received it seems to be right in line. My car originally was
                        set up as a what appears to be the ZR1 (HD Alum Radiator, F41 suspension,
                        radio delete and CGY engine code) but I have no build sheet or
                        protect-o-plate and my research stops in 1987 in GA. I have not been able to
                        figure out how to get info from GA DMV. Until I find some documentation
                        proving it is a ZR1 I will treat it as a plain-jane LT1 and enjoy it just
                        the same
                        Todd
