C2 Help Identifying Rear End ID - NCRS Discussion Boards
  • George C.
    • November 1, 2001
    • 568
    I am having trouble identifying the rear end in my 1965 Roadster. The engine and transmission are original per the numbers, best I can tell. The rear end I can not decode. Stamp on the bottom edge of the case reads
    "2 AM 5 9 68W" I think this decodes to 336 posi. Can you tell me if this is a May 9, 1968 unit?
    Also the part number on the Ring Gear is "3735390 11:37 GM 12-67 2" Does translate to a 336 gear set??
    Thank you in advance,
    George
    #36908
    Re: C2 Help Identifying Rear End ID
    George----
    The "AM" coding indicates the carrier housing was originally fitted with a 3.36:1 gearset. The GM #3735390 part number on the ring gear indicates that it REMAINS fitted with a 3.36:1 gearset. The manufacturing date on the case indicates that this unit was manufactured in 1968, so it could not be original to the car.
    • George C.
      • November 1, 2001
      • 568
      Joe,
      Thanks for the information. I was afraid I was reading it correctly, meaning it was not the original unit. It is not a show car so no real problem here, I am just trying to document everything as I take it apart and clean, paint restore.
      Thanks again for the quick response,
      George
      • Mike E.
        • February 28, 1975
        • 5134
        And if you divide 37 by 11, you get 3.36!
        • Tom D.
          • September 30, 1981
          • 2126
          And the W means Warren, MI *NM*
          https://MichiganNCRS.org
          Michigan Chapter
          Tom Dingman
