Warning: Undefined array key 2157 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Re: 1969 Power Steering Pump -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I wouldn't torque the bolts any more than recommended. Does your car have air conditioning? Is the pulley stamped steel or cast iron? If your car does not have a/c, it should have the cast iron pulley which looks like it is a little thicker according to the pictures. I have not actually compared pulleys side-by-side so I could be wrong.
The car doesn't have AC. I just took a good look at the new and old pulleys and the only difference is that the old one is tapered on the inside and the new one isn't. This seems to be causing the new one to sit about a quarter inch farther out from the pump. They both look steel to me. Have you ever heard of anything like this on one of these pulleys? I'm going to send Eckler's an e-mail too. That's where I bought the pulley. Thanks for your help.
The pulley with the tapered shaft hole is a 63 to 74 pulley. Likely this is a GM #3770509 which is usually stamped on the pulley. This pulley will only work with a pump with a 63-74 pump with a tapered shaft. This shaft has threads on the end for a retaining lock-nut.
The pulley with the non-tapered shaft hole is a 75-82 style pulley. Likely, this is a GM #14023175 which is usually stamped on the pulley, too. This pulley will only work with a 75-82 pump with a non-tapered shaft. The non tapered shaft has no threads on the end and uses no locking device of any kind. It's simply an interference fit between the shaft and the pulley.
The 63-74 and 75-82 pumps are FUNCTIONALLY interchangeable AS A UNIT on any 63-82 Corvette, but the pullies are NOT interchangeable bewteen pump styles. If you use a 75-82 pump on an earlier car, then you have to use the 75-82 pulley, too, and if you use a 63-74 pump on a 75-82, then you have to use a 63-74 pulley, too.
The GM #3770509 pulley is GM-discontinued but available in reproduction. The GM #14023175 is still availabe from GM.
