Re: Blast cabinet hints - NCRS Discussion Boards
  • Chuck S.
    • April 1, 1992
    • 4668
    Chris,
    (1) Ceramic nozzles simply wear longer than steel nozzles. Tungsten nozzles are the longest wearing, but are expensive. Ceramic nozzles are probably a good compromise between service life and expense.
    (2) Nozzle size has only to do with the size of your compressor. Larger nozzles provide more blast media volume, making the work go faster, but they also use more air. If you don't have the compressor capacity to handle the larger media volume, you will have a low velocity at the gun.
    A comment on required compressor capacity: your compressor should not run continuously while you are bead blasting...it should have enough capacity to shut down and rest occasionally. If your compressor runs continously, your don't have enough compressor capacity.
    Blast cabinets are big air users; I believe my 48" Skat-Blast "Pro" cabinet uses 13 cfm @ 100 psi. I have a two-stage 6.5 HP compressor with an 80 gallon reservoir. Typically, the small Craftsman 2-3 HP lube-less compressors will run continuously, and maintain low air pressure that really drags the job out. Because they lack cylinder lubrication, these compressors will be expended pretty quickly.
    (3) If you are working on steel, you will probably want to use your full air system pressure. The higher the pressure, the faster the work goes, however, the time between compressor recovery runs is shorter. On soft materials, like aluminum, you may want to reduce the pressure to avoid inadvertently damaging the part. If you don't want to be monkeying with the air system regulator, you can try holding the gun further away (stretch your holding arm out there ) or hit the piece only with the lower velocity particles at the edge of the media cone.
    Here's another tip: Whenever you have a part that isn't painted, I suggest you use bead-blasting only as a last resort to cleaning the surface. Bead-blasting leaves a matte finish that is atypical of natural cast aluminum or unpainted steel. It will not look right (if you are discriminating), and you could lose judging points.
    Alternately, you can try polishing out the matte finish after the part is cleaned up, but then you could probably have just polished or wire-brushed the corrosion off the piece in the first place.
    Another option is to acid-clean natural parts that must have a "slick" finish; muriatic acid for steel, and phosphoric acid for aluminum (in both cases, the acid should be diluted with water). I have more success cleaning natural steel parts in muriatic acid diluted 1:3 (one part acid, three parts water). If that dilution isn't working well, try increasing the acid strength. I have had less success acid-cleaning aluminum and getting a good result.
    Chuck has given you EXCELLENT advice! You'll get the hang of media blasting with practice and experimentation and shortly wonder how you got along with this tool....
    Having the ability to control air pressure is VERY handy. For coarse work, pressures in the 40-50 psi range do well. On softer materials, like aluminum and pot metal, turning the pressure down to 15-25 psi and keeping the blast nozzle away from the part (one foot or more) help reduce blaster induced pit.
    If your cabinet is new, the observation window is fresh. If you blast without some form of protection on the inside of the glass, it won't be long before you'll be working half-blind through a permanent 'fog' as the inside surface of the glass is etched by stray media. Most who supply cabinets and accessories also supply pre-cut, clear vinyl window protectors that affix via double sided tape. Get a pack and change them as required. It's a LOT easier than replacing the observation glass/gasket!
    Consider purchasing a small quantity of other media to play with. Some of the 'exotics' include industrial garnet, industrial ruby, crushed walnut shells, Etc. You'll find they each have distinct blast properties and you'll quickly learn what works best for which uses....
