My back have worked before. Everythiing is new. One of my lights quit working, I turned on the back-up lights and checked the connection to the light that was out, the plug on the back of the housing was out, when I went to plug it back in the othr light went out and now both lights don't work. The tail light and license lights work. The back-up swith is new, and I know it is adjusted right because it has worked in the past. I haven't noticed a fuse that controls just the back-up lights. What could be the problem? Both bulbs are good. The grounds are connected and the plugs are secure into the back of the housings. What else should I check?
Jeremy Hedges
#31711
Jeremy Hedges
#31711
