DonZ,
-----Just taking a real winger,here,but have you replaced the carpet in your car? If so,do the slices in the carpet under the seat match the original carpets? Did you have the originals to go from? If you dont cut the carpet out from under the seat tracks just as the factory did you will put the seat frames in a bind as you tighten down the two front bolts. The carpet will bunch up underneath in the middle of the seat frame and the frame will bend enough to cause the problem you have mentioned. Hope this helps..........Bill S
