1965 SHP Forged Pistons - NCRS Discussion Boards
  • Tom H.
    • September 30, 2002
    • 136
    Can anyone provide the name of a manufacturer, part number and source for forged replacement pistons for a 1965 SHP 327 ci. engine. Standard bore and compression. Also, does in-kind replacement require rebalancing the entire rotating assembly or can the rods and pistons be match balanced?? Thanks
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 1965 SHP Forged Pistons
    federal mogul,part# L2166NF,10.25:1 CR with 64 CC heads, .125 high dome. weight 580 grams. you will need to check this weight against your old pistons
    • Jimmy B.
      • July 31, 1980
      • 584
      Summit Racing has a great web site and they sell a TRW 10.5 piston something like part # L-1084 (research this part #) but it is to me as close as you'll get. These looked to me identical to the ones removed from my 63 L84 fuelie years ago.
      • Tom H.
        • 136
        THANK YOU *NM* *NM*
