Re: Total advance
Well I am under the impression that the port is usually very near the closed plate position. (Again I may be wrong and getting it confused with the idle circuit ports) Anyway, I thought the plate lifts above the port at anything much above the idle. If that is the case, they would essentially be on the same side of the plate and the only difference between Manifold vac and any point upstream would be a very small amount of friction. Once the plates are openned a certain amount, I don't think there would be much of a localized venturi effect over the port. As the edge of the plate moves away from the wall of the bore, the venturi or choking effect of the throttle is going to decrease exponentially. Even if the port is well above the plate, it would differ from the Manifold vac by only a small amount of friction. But I am just am just an oil patch engineer. I am waiting to hear the rest of the story from one of our resident automotive engineers.
