62 Restoration questions - NCRS Discussion Boards
  • Ron Cwiklinski
    Need advice on the proper method to install the rivets on the trunk spring towers. I removed them to repair stress cracks that formed under the old rivets. I would like to install correct style rivets but I'm having a difficult time in peening over the tail. Thanks in advance for helpfull suggestions.
    Ron's 62 project
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 62 Restoration questions
    make a dolly that'll "fit" the head of the rivit(i used an old c-1 king pin, drilled a superficial hole in the end of the king pin just deep enough and diameter that of the head of the rivet) . then get your buddy to dolly the head while you peen the tail with a ballpeen hammer.mike
    • James B.
      • September 30, 2005
      • 115
      Ron,
      If you are interested, I have a restoration of a '62 on VHS available- It doesn't cover the spring towers, but it does cover alot more. Contact me at jmbiii@yahoo.com if you would like more details.
      Jim
        Ron, call Richard Dunham, our Judging Chairman - he has the correct rivets for that application, and a tool he fabricated to peen them.
        • Ron Cwiklinski
          Thanks John, Jim and Mike.
