I have a queston regarding the steering box on my SWC. I want to tighten up my loose steering have isolated the problem to the box. The Shop Manual prochedure involves removal of the pitman arm nut and piston arm using tool J-6632 and measuring pull at the rim using tool J-0544.
Can I just try simply adjusting the pitman lash adjuster screw to see if the looseness will be gone or, at least, eliminated?
The Shop Manual also discusses adjusting worm bearings. The Manual is not too clear as to where the worm bearing adjuster lock nut and worm bearing adjuster is located. Again, can this adjustment be made without going through the entire Shop Manual prochedure?
I realize that there are probably no shortcuts, but I feel I should at least ask.
Dick
Dick
