C2 knock off wheels - NCRS Discussion Boards
C2 knock off wheels
  • Ron Calcaterra
    C2 knock off wheels
    I need some help. I have a 65 Roadster with knock off wheels. My brakes went our and I suppect the front caliper.
    I have not able to remove the locking nut even after several attempts, using an 8# mallet.
    The wheel have not been off for about 6 years, (1,000 miles)
    Any suggestions??
    Also can anyone recommend a C2 mechanic in Columbia,South Carolina if I can not get the wheel off.
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C2 knock off wheels
    Is that an 8 lb. mallet? I have to ask. Are they repros and if so, did you remove the locking pins first. The only thing that you want to use on them is a lead hammer or maybe one of those special wrenches.
    • Jack W.
      • August 31, 2000
      • 358
      one suggestion from someone who should have known better: If it is a left-side wheel, pay attention to what Mr. Off Arrow is trying to tell you. The left-side spinners are reverse threaded, meaning you need to whack them clockwise to remove them.
        If the adapters are correctly installed, the driver's side spinners are right-hand thread, and the passenger side spinners are left-hand thread; in any event, the arrow on the spinner tells the story. Pop the emblem off and check for pins (if they're reproduction wheels).
        • John Pickens
          Best way to remove the center cap without damage is...??
          • Jack W.
            • August 31, 2000
            • 358
            I knew I had gotten it wrong (d-side vs p-side thread distinction) the minute I posted but I canot edit a post, of course. Oh well. Last time I was whacking and whacking at a KO spinner with no movement I had forgotten to pay attention to what the arrow was telling me (years of leftie-loosie training have a way of creeping back into the mind); I am willing to bet this is his problem too.
              Carefully pry at the edges with screwdriver.... *NM*
              • Don H.
                • December 1, 1981
                • 1482
                Re: Carefully pry at the edges with screwdriver...
                Contact Long Island Corvette and spend $8 for their suction cup to remove the cap. Works great and NO scratches, well worth the money! Don H.
