Re: Damn, Jerry, that's no fun....
I was hoping you'd disagree because it's very close to the flip side of the radiator deal so I was hoping to catch you playing both sides of the equation.
Everett, who apparently types much faster or has much more free time than I do, has put forth a coherent view of our side. I am still unmoved by your, "don't worry about catching that Btu now, the coolant shall pass this way again" argument. I can't endorse the idea that because the the coolant recirculates you have found a way around heat transfer being a function of time. If you stuck a hose in the radiator neck, yeah okay, I'm on your bus but since the coolant is captive, even though recirculating, I think you have to take the most advantage of every second you have to cool the block and the coolant and I think the max diffential gives max efficiency.
Think of the 2 extremes, no flow it overheats, no time in contact it overheats. So the answer lies somewhere between the 2 and my belief is that it leans toward the less flow/greater temp differential side (in theory, not necessarily in reality for ever single weather condition, design, driving style, age, use and abuse of equipment). I wish I could summon the ambition to try to prove this thing out but I'm way too old and lazy for that.
JP
P.S. If it turns out that we, who retain water, do eventually prevail, I expect to see you at the National Convention, in your 'running suit', installing a thermostat in your car. ;)
JP
