Door key - my car didn't come with one when I bought it. Is there a number somewhere, maybe on the door lock cylinder, that I can use to have one cut? If not, is there an alternative outside of buying a new set?
Alarm - Did my car have one from the factory? I have a horn inside the right front fenderwell, and an electrical switch on the drivers side door lock. However, there's not the ususal key activator anywhere on the body work, and absolutely non on the front fender like I'm used to seeing. Or is it activated by the electrical switch on the door lock cylinder?
Radio/AC control light - Mine comes on and goes off intermittently as I drive. And I can't figure out what's setting it off. What determines when this light is on and when it's off? Should it be on all the time, or is it tied to the dome light or courtesy lights?
Vapor canister hose - I have one that's just hanging loose in the engine compartment. But none of them off the canister are hooked to the carb (a Holley on an Edlebrock manifold). My suspision is that this hose should in fact be hooked to the carb to pull the extra fumes into the engine. Can anyone confirm this?
As Always, Thanks!
W
As Always, Thanks!
W
