I bought a remanufactured by GM A/C compressor (A-6) for my '73. Upon close inspection, there is no provision for a superheat switch in compressor. To the best of my knowledge, all of the Chevy A-6 compressors were the same. Was there a production change regarding this and if so when/why? Also, since a lead from the thermal fuse/limiter connects to this to guard against a high temp. low pressure condition, how is this guarded against if there is no superheat switch? Did GM make a retrofit low pressure switch or some other option to take its place? Even though the system will operate without the switch, I don't want to have a system "meltdown" one day. Any help would be appreciated. Thanks, Jim - Elkhart '73
A/C Compressor superheat switch
Tag line
Curious, I thought AC-Delco rebuilds were the ONLY source you could trust for 'correct' matching of A-6 to application via part number. The other big rebuilders (NAPA, Etc.) are known to simply inter-mix passenger car configurations (12.6 cu in displacement vs. Corvette's unique 10.8 cu in displacement, note also used on other 'Chevy A/C' systems vs. Four Seasons -- read this truck and/or dealer underdash installs) and early/late style A-6 under a common application part number....- Top
Tag line
