Does anyone know a trick on the best way to install the upper door panel metal supports on new door panels? The staples in the door panel metal supports are in good shape. Should I somehow try to locate the support, and use the staples to mark spots and then punch those holes in the carboard? The problem is that the new door panels are already stretched and glued on the sides almost to the top. It seems nearly impossible to get to where the staples go for the metal supports without unglueing the vinyl on the new door panels part way down. I thought there must be a better way.....
Kevin Riel
Kevin Riel
