C3 Points/Condensor - NCRS Discussion Boards
C3 Points/Condensor
  • Jim T.
    • March 1, 1993
    • 5351
    C3 Points/Condensor
    If a condensor has failed, what effect would it have on a 68's ignition system?
    • 15610
    Re: C3 Points/Condensor
    If the condenser fails open the points would burn rapidly. If it shorted the car probably wouldn't run because the primary circuit is shorted.
    If you measure a capacitor with an ohmmeter it should read infinite resistance, but that doesn't mean it's good. Measuring actual capacitance and leak rate requires special equipment, but I doubt if they fail very often - very simple and rugged device.
    • Jim T.
      • March 1, 1993
      • 5351
      Thanks Duke.
